problems with ps.map in GRASS5beta8
Il Sat, 19 August 2000, Markus Neteler ha scritto:
On Wed, Aug 09, 2000 at 12:09:03PM +0200, chiara sboarina wrote:
> Hi all, when I run ps.map it doesn't work and the next message appears:
> ERROR: unable to exec ps.map.new
> I searched for ps.map.new in grass5.0beta8_linux.tar.gz but the only file I found is /man/2/ps.map.new.
> I'd like to know if the bin file of ps.map.new exist in grass5beta8 or if the problem is a bug of ps.map.
> Thank you
Hi Chiara,
sorry for this bug: The module was renamed and we missed to
correct it internally.
You can try to overcome the problem by adding a link
(it will be fixed in the next version of GRASS).
cd $GISBASE
cd bin
ln -s ps.map ps.map.new
Please tell me if this helps.
This link is not enough so I've added symbolic links to all ps.map files in $GISBASE/etc/bin/main and now it works.
Thank you
Chiara
___________________________________________________
Se vuoi un indirizzo di posta elettronica gratuito,
iscriviti a http://www.katamail.com
