Steve Culshaw writes:
Can someone explain to me - fairly simply as I'm not too sure what I'm
doing - why I can't get my altered version of ps.map to work. This is
even more bewildering when my previous change (decreased line thickness)
seemed to work ?I've found three 'ps.map' files
- one in GRASS/bin - identical in size to all the other programs - 24576
bytes- one each in GRASS/etc/bin/alpha/cmd and GRASS/etc/bin/alpha/inter
- much biggerWhen I run 'gamke4.1' in the src/alpha/../ps.map directory, I find the
/cmd version has been updated, but when I run ps.map from in grass, I
don't see the changes I've made.
Steve,
Assuming that you're leaving GRASS up and running while you compile your
altered program, you probably need to execute the "rehash" command from your
GRASS window before you attempt to run the altered ps.map.
Let me know if this doesn't do the trick.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
