Hi Grasser,
I would like to know if there is any Grasser knows how to set projection in Grass 4.2.1/5 to the Malaysia/Sarawak Borneo RSO Projection, with the 2,xxx,xxx meters Easting and 5,xxx,xxx meters Northing coordinates. (The 2 & 5 millions are false coordinates that offset the negative Easting values towards southwest part of Sarawak).
I can provides the projection parameters as used in Arc/Info or Genamap if anybody is interested.
Thank you
Bong Khin Fah
Kuching, Sarawak
