Hello,
I just wanted to know what type of projections are supported by
GRASS and if (in particular) tranverse mercator is supported.
TIA
One must note the importance of setting reasonable and achievable goals for
"If you aim for nothing, you'll hit it every time"
-Theodore Roosevelt
Universal Transverse Mercator (UTM) is the only fully-supported projection.
There is significant, but not complete, support for Lat/Lon.
Eric
Hi Casey,
With the use of the Proj 4 program that was incorporated into GRASS from
the USGS, you can convert to many projections. Proj 4 should be in the GRASS
release. Rick
Hello,
Rick Thompson- Research Specialist E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-8498
Ozark Hall Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
