ps.map and grid command
Good Afternoon,
Has anyone had probelsm with specifying a coordinate grid in ps.map ?
ps.map specifies the grid in meters , asking for one values , but this
only produces on lon line when I execute the ps.map command. ?
I'm trying to specify a 50km grid but no luck, that is the grid isn't
showing on the hardcopy output ?
Any one seen this before ?
Thanks
Jeremy
Jeremy,
I too have had a problem getting ps.map to produce grids (as well as
labels) on my hardcopy. What I've done is bypass the problem by using a
screengrabber program (Xv) to grab my map and then print it.
Bradley D. Robbins brobbins@chuma.cas.usf.edu
Department of Biology (voice) 813-974-5420
University of South Florida (fax) 813-974-3263
Tampa, FL 33620
              "Isn't it all just a question of scale?"
On Wed, 22 Feb 1995, DUNN JEREMY SIMON wrote:
Good Afternoon,
Thanks
Jeremy
