motte writes:
Received: from diego.cecer.army.mil by aec1.apgea.army.mil id aa03246;
6 Oct 95 5:57 EDT
Received: (from daemon@localhost) by diego.cecer.army.mil (8.6.9/8.6.9) id DAA17399 for grassu-people; Fri, 6 Oct 1995 03:23:26 -0500
Received: from max.cecer.army.mil (max.cecer.army.mil [129.229.20.254]) by diego.cecer.army.mil (8.6.9/8.6.9) with ESMTP id DAA17396 for <grassu-list@diego.cecer.army.mil>; Fri, 6 Oct 1995 03:23:23 -0500
Received: from xs1.xs4all.nl (motte@xs1.xs4all.nl [193.78.33.42]) by max.cecer.army.mil (8.6.9/8.6.9) with SMTP id DAA14201 for <grassu-list@max.cecer.army.mil>; Fri, 6 Oct 1995 03:23:15 -0500
Received: by xs1.xs4all.nl id AA26138
(5.67b/IDA-1.5 for grassu-list@max.cecer.army.mil); Fri, 6 Oct 1995 09:23:21 +0100
Message-Id: <199510060823.AA26138@xs1.xs4all.nl>
Subject: Re: ps.map, hp650c's and paper wasting
Sender: grass-lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Date: Fri, 6 Oct 1995 09:23:20 +0100 (MET)
In-Reply-To: <9510052239.AA06658@lewis-deh2.army.mil> from "Stuart Bradshaw" at Oct 5, 95 03:39:47 pm
X-Mailer: ELM [version 2.4 PL21]
Content-Type: text
Content-Length: 878There is a shell program at moon.cecer.army.mil called add.pagesize.
This puts in a pagesize command into the postscript file and helps with
the paper waste problem.Do remember to edit the file if you're going to use A4 or A3 sized
sheets, because the standard version of add.pagesize includes a 200 pixel
wide left and top margin to the original postscript file, which is quite
a lot on a small sheet. By the way, the problem seems to be HP: there is
no such command as 'pagesize' in the original PostScript language, but HP
printers which read it expect the pagesize to be included.Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
