I am running the grass4.1 binaries from topquark with the slackware
distribution of linux. I have run up against a problem with ps.map.
At the first try at execution, it produces the error "floating point
exception". The command executes at the second attempt, but
in the postscript output file all raster
levels are assigned the color of the first level. Vectors, titles,and
colortables are created as expected. Has anyone noticed this problem,
or have a solution for it?
Gerry Whittaker
Economic Research Service, USDA
gerryw@ers.bitnet
