ps.map output can not be used in Corel Draw or whatever. Usually
these programs can only import Adobe Illustrator EPS, which
is a postscript dialect. Translating GRASS-postscript into AI-eps
format cannot be done automaticly as far as I can see.
If you want to edit grass maps, I would suggest to export raster
maps as tiff and vector maps as dxf, and assemble the two in
Corel!.
Ronald Wiemer
R.O.B. / Archis
Kerkstraat 1
NL 3811 CV Amersfoort
The Netherlands
Tel: ++ 31 33 4634233
Fax: ++ 31 33 4653235
Ronald Wiemer wrote:
try ghostscript which can convert ps to eps and ai format (files:
ps2epsi.ps and ps2ai.ps). IMHO ghostscript should be installed on
every UNIX box.
Servus Henning
Henning Brockfeld Institut fuer Wirtschaftsgeographie
Universitaet Muenchen
mailto:Henning.Brockfeld@lrz.uni-muenchen.de
http://miraculix.wigeo.bwl.uni-muenchen.de/~hbrock/
