ps.map postscript
Some time ago there was a discussion about the postscript produced by
ps.map. The problem was that the ps.map postscript files could not be
read in by other programs. I generated a postscript file with the new
version of ps.map from grass/incoming, then tried to load it with xv,
but xv will not recognize it as an image file. The header in the
ps.map postscript file does indicate "%!PS-Adobe-3.0 EPSF-3.0" which
suggests it is an encapsulated postscript file. Was this problem ever
resolved?
  Bill Baker
  bakerwl@uwyo.edu
Bill,
I'm not an expert on this, but I do not believe that ps.map writes in strictly
encapsulated postscript. In order to view a file you're going to need a real
postscript viewer, such as GhostScript (GhostView?) or Sun's Pageview.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
