ps.map postscript
> read in by other programs. I generated a postscript file with the new
> version of ps.map from grass/incoming, then tried to load it with xv,
> but xv will not recognize it as an image file. The header in the
> ps.map postscript file does indicate "%!PS-Adobe-3.0 EPSF-3.0" which
> suggests it is an encapsulated postscript file. Was this problem ever
> resolved?
> Bill Baker
> bakerwl@uwyo.edu
Bill,
I'm not an expert on this, but I do not believe that ps.map writes in strictly
encapsulated postscript. In order to view a file you're going to need a real
postscript viewer, such as GhostScript (GhostView?) or Sun's Pageview.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Malcolm's right about ghostview--it works fine for us under SunOS 4.1.3
and Solaris 2.3 both. On a related note, if your printer can't handle
Adobe 3 (as our color laser printer can't), try using psfix to translate
to Adobe 2:
            psfix mapfile.ps > fixmap.ps
(There doesn't seem to be a man page for it.)
John Mackenzie
U. of Delaware
