ps.map problem w.vectors in Linux
The grass vector file format seems to be very wasty on
disk space. I had one which is about 50 MB, but only 30 MB in ARC/INFO.
Maybe someone can work on a compressed version.
This is particularly the case if you have editted it, but not
run it through v.clean to remove all the deleted lines. Just a reminder.
Simon Cox
_________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
      Phone +61 9 284 8443 + ___ / Research
      Fax +61 9 389 1906 L~~' "\__/ Centre
simon@ned.dem.csiro.au W
AGCRC info>> http://www.ned.dem.csiro.au/AGCRC/
