ps.map problems with vectors
There seems to be a problem with setting the width of the
vector file lines. Here is what I'm doing in my input
file
vector disk.springlake
color black
width 5
masked n
end
I can change the width line to any number and it will not
affect the line. Is there a reason?
Kym M. Lenkus
Davidson Laboratory
Hi Kym
I can't put my finger on *exactly* what is causing your problem, but I can
attest that the following works fine for me:
vect mymap.majrds
color red
width 1
end
It could be something to do with the difference between "vector" and "vect", or
possibly the indent on your width command, or maybe the fact that you are using
very wide lines - your guess is as good as mine! Let me know if you figure it
out!
Good luck,
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
