ps.map problems with vectors
> Hi,
> There seems to be a problem with setting the width of the
> vector file lines. Here is what I'm doing in my input
> file
> vector disk.springlake
> color black
> width 5
> masked n
> end
> I can change the width line to any number and it will not
> affect the line. Is there a reason?
> Kym M. Lenkus
> Davidson Laboratory
Hi Kym
I can't put my finger on *exactly* what is causing your problem, but I can
attest that the following works fine for me:
vect mymap.majrds
color red
width 1
end
It could be something to do with the difference between "vector" and "vect", or
possibly the indent on your width command, or maybe the fact that you are using
very wide lines - your guess is as good as mine! Let me know if you figure it
out!
Good luck,
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
Kym, you're probably using an old version of ps.map - I had the same
trouble with the vector widths; try to get the newest version off teh moon!
Philip Verhagen
      S t i c h t i n g R A A P
    Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
          1018 TV Amsterdam
           THE NETHERLANDS
phone/fax: (31) 20 525 5834
e-mail: motte@hacktic.nl
