ps.map
After I create my output file using ps.map how do I print it?
I am using a Sparcprinter with Newsprint. Do I use lpr, pl
and then filename. I saw some discussion about plotter and
plot.sh.
Thanks for the help,
Jim
With NewsPrint, you should be able to treat the PostScript file just like a text
file: lpr filename, or lpr -Pprinter_name filename (if you must specify your
printer).
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
