Before I start let me say that I am
running a copy of grass4.2.1 version 18 on a FreeBSD machine. I also
compiled the code on this machine.
ps.map: I am finding that the ps.map is giving a segmentation fault
when I attempt to use vector files. Raster files and sites work fine.
If I ask the program to paint raster files and vector files, there is
no segmentation fault, but the vector information does not appear. Is
this the "same old ps.map problem" ? If so, what is the appropriate
fix?
Allan E. Strand stranda@cofc.edu, http://linum.cofc.edu
Department of Biology Phone: (843) 953-8085
College of Charleston Fax: (843) 953-5453
Charleston, SC 29424
Allan Strand wrote:
fix?
Ouch. No that is *not* the same old ps.map problem. Off of the top of
my head, I would guess something is wrong in the process of converting
the vector to postscript. If you have a core file lying around
somewhere I might be able to tell you. I have to move to the latest
anyways, I'm still somewhere in the early teens (heh!)
This seems to be a recent bug. I remember printing vectors just fine
when
I fixed that FIRST ps.map bug.
Clifton B. Wood
Programmer/Analyst for the Entomology Dept. of Va. Tech.
------------------ Thought of the Decade -------------------
windows98 = n. 64 patches to 32 bit extensions and a graphical
shell for a 16 bit patch to an 8 bit operating system originally
coded for a 4 bit microprocessor, written by a 2 bit company
that can't stand 1 bit of competition.
