ps.select problems
I defined an A3-Postscript device driver for GRASS4.1.3 on RS/6000 named
/grass4.1/etc/paint/ps.devices/abc with the following specifications:
        level: 2
        page width: 11.69
        page height: 16.53
        top margin: 0.5
        bottom margin: 0.5
        left margin: 0.25
        right margin 0.25
        resolution: 400
When I try to select this device using ps.device painter=abc, I`ve got the
message:
        Illegal parameter range for painter
        legal range (nabc)
Does anybody know, what`s going on there and what I have to do to get this
printer selected ?
Thanks in advance
Ralf Kunkel
I had the same problem. It seems that the command just reads what it wants
from the command line. It's not a technical explanation, but this is the
impression I had.
I went over the problem by modifying the source to use as defaults the parameters
for A4 paper. But if you need to change format, this won't do!
          Andrea Giacomelli
          andreag@idra1.iar.polimi.it
          DIIAR Politecnico di Milano, Italia
