ps.select
In article <199405170815.DAA13584@max.cecer.army.mil> you write:
: Ok! The strange thing now is that I created the ps.devices directory with a
: file named hp in it, containing this info, but ps.select doesn't accept
: hp as a legal value (though it lists it with the -l option)...what is going
: on ?
: ...nearly there...
: Andrea G.
Did you put your printer file to $GISBASE/etc/paint/ps.devices -subdirectory ?
($GISBASE is your grass-location /usr/local/grass etc..)
(I'm sorry to bother you once more.)
I did. The result of ps.select seems to be unpredictable:
This is what I have in the ps.devices directory:
/users/andreag/Grass/etc/paint/ps.devices
total 2
-rw-rw-rw- 1 andreag users 131 May 17 09:47 hp
This is what happens giving 'ps.select -l':
hp
...so it seems that Grass sees my file.
But, if I give 'ps.select painter=hp' this is what I get:
Error: value <hp> out of range for parameter <painter>
       Legal range: MONITOR:@hp
Usage:
ps.select [-lpq] [painter=name]
Flags:
  -l list all available PostScript painters
  -p print name of currently selected PostScript painter
  -q quietly select PostScript painter
Parameters:
  painter name of PostScript painter to select
            options: MONITOR:@hp
However, I managed to select once my hp file, and then everything worked fine,
other times, instead of MONITOR:@hp I get PSPAINTE:@hp or things like this.
            Andrea Giacomelli
            andreag@idra1.iar.polimi.it
