psfile in ps.map
t?Mar?15??95?12?14?49?pm@bnr.ca>
Reply-To: grassu-list@max.cecer.army.mil
NNTP-Posting-Host: ux1.cso.uiuc.edu
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Originator: daemon@ux1.cso.uiuc.edu
Hello
You need to modify the Postscript file containing the logo before
calling it from ps.map.
1. The beginning up to and including %EndProlog must be stripped
2. any lines after "grestore" (at the end of the file) must also be stripped
3. the size can be changed by modifying the "scale" instruction
    e.g. 4 inch 1.6 inch scale
4. the location can be changed by modifying the "translate"
   instruction
    e.g. 0 inch 0.18 inch translate
    it sets the position of the logo's lower-left corner, the
    lower-left corner of your plot is the origin..
Good Luck.
Who knows who you can position a postscript file included in your with ps.map
script with psfile.
My included logo postscript file is somewhere put at the top of my raster
file defined in ps.map (the command where does not work in combination
with psfile).
Anne Gisiger FAX: (501) 575-5218
CAST, Center for Advanced Spatial Technologies TEL: (501) 575-6159
12 Ozark Hall, University of Arkansas
Fayetteville AR 72701 anne@cast.uark.edu
                Mosaic Page for CAST: http://www.cast.uark.edu
