I'm having a problem importing with v.import ungenerated ARC/Info line
files of
hydrologic features. Importing seemed to go fine but returned the
following warning from v.support for more than a thousand lines:
WARNING: line 2473 label: 11 matched another label: 11.
WARNING: line 2474 label: 11 matched another label: 11.
et.c.
I ignored this messages but it turned out that when I try to
rasterize this map I lost corresponding attributes. And if I try to
reproject this map I get a "bad lines" response for that lines with
warning from v.support and can't build the topology for the
reprojected map. Does anybody know what this warning means and how to
avoid it?
Thanks
Helena Voinov
Univ.of Maryland Inst.for Ecological Economics
Center for Environmental and Estuarine Studies
P.O. Box 38, Solomons, MD 20688
TEL: (410) 326 7248
FAX: (410) 326 7354
