Markus,
You can use first the v.cutter to extract the less
quality data with a vector that has the extents of your
good quality data and then use v.patch to overlay the good qual
Regards
Alejadnro Hinojosa
currently I have the problem to merge a small vector map
in good digitizing quality and a second in less quality.
The small one is part of the second - I want to *replace*
a part of the map with less quality by overlaying this
small map:-------------
|less qual. |
| |good| |
| |qual| |
-------------How to perform such replacement in GRASS? I feel that v.patch
will just overlay both maps.Thanks for assistance
