question on Arc/Info attributes
Since you mention using SQL, does this imply that the only way for GRASS
to query multiple attributes is through a database? If so, then our
problem is basically solved since we are currently working on a
GRASS-POSTGRES interface (the one on moon did not meet our requirements).
We are trying to find out if GRASS could perform a multiple attribute
query without a database but it doesn't seem that it can.
Thank you for your kind offer to write the query for us but I don't think
we should bother you with such a trivial matter.
Thanks for your help.
Which sql solution did you try? I just put a grass-sql archive there
recently. It isn't really meant as a full solution but it works well
with what we are doing... I have also written a GUI using xforms to
build the sql queries easier... Anyway if it was my program that
didn't fit, what exactly are your requirements? I am interested as I
think it is a powerful solution...
Richard Nairn |
Calgary, AB, Canada | "So many idiots,
email --> nairnr@cadvision.com | So few Comets..."
** Powered by Linux 2.0.29 ** |
