Date: Thu, 10 Jun 1993 11:40:50 -0400
To: grassp-list@max.cecer.army.mil
Subject: questionWhat is /usr/bin/ranlib?
--Xin
zhaung@access.digex.com
Program ranlib is an artifact of UCB Unix which basically puts a
record of information of contents of an archive libary. It must
be executed after updating object modules in the library. For
example:
ar -r libxxx.a file1.o file2.o
ranlib libxxx.a
Failure to do so will cause the linker to choke.
USL Unix does not use ranlib.
In generalize makefiles one often sees the test for the existance
of /bin/ranlib or /usr/bin/ranlib in a conditional for its execution
after makeing a library.
Gerald (Jerry) I. Evenden Internet: gie@charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
fax: (508)457-2310 N.Falmouth, MA 02556-1027
