questions
you might find the Shareware TOPAZ from Gabrecht and Martz helpful to
delineate subbasins. The output is in ascii format and no big trouble
to import that into a GIS. Another option might be the r.watershed
comand in GRASS.
Nicola
Hi everyone
I am a graduate student at the university of arizona, I want to use DEMON
algorithm to delineate subbasin, the software I am using is Arc/Info. But
so far, this algorithm has not been combined with arc/Info. I want to use
this method by GRASS, and then change the result fime to Arc/Info format,
I just know a little about GRASS. would you like give me some suggestion
and answer the following questions:
1. is this idear pratical? i.e. is there the function to delineate
subbasin by DEMON algorithm in GRASS?
2. how to change Arc/info data format into GRASS format
3. how to use this algorithm
hope to receive your early reply
thanks
Lihong Zhang
Dr. sc. agr. Nicola Fohrer
Wissenschaftliche Assistentin
Institut fuer Landeskultur
Senckenbergstr. 3
35 390 Giessen
Tel:0641/99 37385
Fax:0641/99 37389
email:Nicola.Fohrer@agrar.uni-giessen.de
Hi Nicola
thanks for your advice. I know tapes have no the function to delineate
subbasin, but just calculate areas. I am trying to use r.watershed now.
lihong
On Tue, 24 Aug 1999, Nicola Fohrer wrote:
comand in GRASS.
Nicola
> Hi everyone
> thanks
> Lihong Zhang
Senckenbergstr. 3
35 390 Giessen
Tel:0641/99 37385
Fax:0641/99 37389
Lihong Zhang
