r.agnps.run
From owner-grassu@isis.cecer.army.mil Wed Aug 21 19:04:35 1996
X-Authentication-Warning: isis.cecer.army.mil: listserv set sender to grassu
using -f
Subject: r.agnps.run
I have installed the r.agnps routines on a DecStation 5000/120
running Ultrix 4.13. We have been sucessful in getting the
r.agnps.input routine to work but the r.agnps.run routine appears
to cause the system to hang-up.
Can anyone suggest what the problem may be and how to resolve it?
Anne M. Smith
Agriculture and Agri-Food Canada
Research Centre
Lethbridge
Alberta, T1J 4B1
smitha@abrsle.agr.ca
look at the bin directory where you have installed r.aganps
if you find either agrun or agnps, try
agrun <inputfile (or)
agrun (hit return)
inputfile (hit return)
hope this helps.
Srini
