r.buffer
I am trying to buffer a very large file at a high
resolution to ensure accuracy of road definition.
I am using GRASS version 4.1.3 NRCS version operating on
SunOS.
r.buffer input='proad@PERMANENT' output='proadbuff'
units='meters' distances='3'
ERROR: G_malloc: out of memory
I was thinking that I had buffered a similar coverage very
recently and am not sure why am incurring this error...
Any suggestions??
Many Thanks
Anna Edwards
University of Georgia
SunOS.
Any suggestions??
Many Thanks
Anna Edwards
Anna Edwards,
I had the same problem. The cause of this probelm is not enough
swap space. To see how much swap space you have run /etc/pstat -T
you see the total amount of swap sapce and the total amount being used.
To increase this swap space
login as su root
cd to a directory where you can use 100MBs of space.
mkdir -v 100MB swapfile
after this run swapon -a( This will tirn on the new swap space)
run /etc/pstat -T you see the new swap space.
Also clean out your /tmp, /var/tmp, /var/adm/messages if the are large.
the way I do it is to copy an empty file over the large message file.
Johnny Duke
GIS Tech
USDA/NRCS
jduke@ar.nrcs.usda.gov
