R: [Geoserver-devel] hi
I added a JIRA task on how to use the new MIFDataStore with GeoServer:
  http://jira.codehaus.org/browse/GEOS-375
Note that it applies to GeoServer 1.3.0-RC1. It may work with earlier
versions,
but I didn't tested it, nor I ever will...
For any question please add a comment to the JIRA task itself or post to
this list.
Bye
Paolo Rizzi
-----Messaggio originale-----
Da: Luca Sigfrido Percich [mailto:luca.percich@anonymised.com]
Inviato: giovedì 7 luglio 2005 17.06
A: Omar Zevallos; Chris Holmes
Cc: geoserver-devel@lists.sourceforge.net
Oggetto: Re: [Geoserver-devel] hi
HI all,
On 7 Jul 2005 at 10:35, Chris Holmes wrote:
> > Hi, I have installed GeoServer 1.2.
> > does it work with MapInfo Files directly (.map, .dat)?
The native binary format (.tab + .dat + .map + .id + .ind) is not
supported.
We developed a MIFDataStore which can read and write MapInfo
Interchange Format (.mif / .mid) files.
A possible workaround for now is using the tab2tab utility (see
http://mitab.maptools.org) for converting your tab files into mif
format, then you can access the mif files within GeoServer.
You can find more info, and the .jar file, at:
http://www.geotools.org/MIFDataStore
> Sig - it might be nice to make a task in geoserver called 'add
> mapinfo', and there you can attach the latest built jar, and people
> can just drop it in (give directions as to how to, but it should be
> straightforward - add to lib directory, will show up on drop down in
> web admin tool, ect.)
Ok, I'll do it!
Best regards
Sig
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
Geoserver-devel mailing list
Hi all, I thanks you for the answers. I try to test the MIFDataStore with
GeoServer 1.2.4, but don´t work with this version (gt2-main.jar) becouse
don´t suport the org/geotools/feature/FeatureTypeBuilder. My cuestion is:
can I work with the GeoServer 1.2.4 code and the gt2-main.jar of the
GeoServer 1.3? to use the MIFDataStore...
Regards.
----- Original Message -----
From: "P. Rizzi Ag.Mobilità Ambiente" <paolo.rizzi@anonymised.com>
To: "L.Percich Ag.Mobilità Ambiente" <luca.percich@anonymised.com>; "Omar
Zevallos" <omzeta@anonymised.com>; "Chris Holmes" <cholmes@anonymised.com>
Cc: <geoserver-devel@lists.sourceforge.net>
Sent: Tuesday, July 12, 2005 5:33 AM
Subject: R: [Geoserver-devel] hi
versions,
this list.
Bye
Paolo Rizzi
> HI all,
> supported.
> Ok, I'll do it!
> Best regards
> Sig
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Quoting Omar Zevallos <omzeta@anonymised.com>:
with
becouse
is:
Unfortunately I don't think you can. There were too many changes
between gt 2.0 and 2.1. I was quite upset about this, but there's not
much we could do about it. So you'll have to use 1.3 to use
MIFDataStore. It's getting pretty stable though, the next release
should be just as good as 1.2.4, and better in many ways.
best regards,
Chris
Regards.
GeoServer:
earlier
> versions,
post to
> this list.
> Bye
> Paolo Rizzi
> > HI all,
> > supported.
people
should be
down in
> > Ok, I'll do it!
> > Best regards
> > Sig
Strategies
articles,
to
> > speed, fast.
> > _______________________________________________
This mail sent through IMP: https://webmail.limegroup.com/
