There are bugs in GeoTools support for Dates/Times, see:
http://jira.codehaus.org/browse/GEOT-619
http://jira.codehaus.org/browse/GEOT-620
and it makes me think the bug you filed is caused by the above ones.
I don't know if those were fixed in recent GeoTools versions,
but I suspect they weren't...
Bye
Paolo Rizzi
-----Messaggio originale-----
Da: Amr A. Alam (JIRA) [mailto:jira@anonymised.com]
Inviato: giovedì 23 febbraio 2006 1.14
A: geoserver-devel@lists.sourceforge.net
Oggetto: [Geoserver-devel] [jira] Created: (GEOS-571) Cannot
set type to
DateCannot set type to Date
-----------------------Key: GEOS-571
URL: http://jira.codehaus.org/browse/GEOS-571
Project: GeoServer
Type: BugComponents: Configuration
Versions: 1.3.0 RC7
Environment: Win XP
Reporter: Amr A. Alam
Assigned to: dblasby
Priority: CriticalSetting up WFS backed by a postgis DB.
I have a column of type date in postgis. In geoserver, this
shows up as dateTime by default; that's fine, but when I
change it to 'date' (which is an available option) the
feature type description doesn't seem to be affected at all!this is what i get for that attribute regardless of whether
i've picked 'date' or 'dateTime'.
<xs:element name="creationdate" minOccurs="0" nillable="true"
type="xs:dateTime"/>This basically makes it impossible to upload to (using
geotools) if the date field is set to anything.--
If you think it was sent incorrectly contact one of the
administrators:
For more information on JIRA, see:
http://www.atlassian.com/software/jira-------------------------------------------------------
This SF.Net email is sponsored by xPML, a groundbreaking
scripting language
that extends applications into web and mobile media. Attend
the live webcast
and join the prime developer group breaking into this new
coding territory!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&
dat=121642
Geoserver-devel mailing list
AVVERTENZE AI SENSI DEL D. LGS. 196/2003
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i, sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceveste questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema; costituisce comportamento contrario ai
principi dettati dal D. Lgs. 196/2003 il trattenere il messaggio stesso,
utilizzarlo per finalità diverse.
