R: [Geoserver-devel] Multiple GeoServers vs Singletons
-----Messaggio originale-----
Da: David Zwiers [mailto:david.zwiers@anonymised.com]
Paolo,
I get your drift ... the answer is Yes, there could potnetially be
problems with multiple Geoserver instances
affecting each other. Singletons are used within Geotools (some of the
Factory code used to ... the XML code
definititely does). This could create some issues with both shared
transactions, shared schema parses (naming
conflicts) ... or even shared DataStore instances (SDE connections are
singletons too I think).
Hope this helps start your list ... sorry for the bad news,
David
The bad news are not for me actually, because the original poster was
Stephen Taylor I believe...
Anyway, if things are like this, the container must give each GeoServer
instance its own JVM,
otherwise there will be singleton conflicts. Is this right???
If this is right I don't know if and how Tomcat can do that.
Bye
Paolo
On 2/14/06, Jody Garnett <jgarnett@anonymised.com> wrote:
P.Rizzi Ag.Mobilità Ambiente wrote:
of the same version of GeoServer and not two different versions, like
having
a 1.3.0 and a 1.2.0 running inside the same container. That would have
been
more difficult.
The only thing that could be a problem are singletons, and I can't
rembember
if there are any in GeoServer. Maybe DataStores/Transaction can soffer,
but
I'm not sure.
GeoServer puts all its "singletons" in the application context - so we
should be good here. If you find anything
that breaks let us know.
Jody
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://sel.as-us.falkag.net/sel?cmdlnk&kid3432&bid#0486&dat1642
Geoserver-devel mailing list
AVVERTENZE AI SENSI DEL D. LGS. 196/2003
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i, sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceveste questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema; costituisce comportamento contrario ai
principi dettati dal D. Lgs. 196/2003 il trattenere il messaggio stesso,
utilizzarlo per finalità diverse.
