You should look in the container log and see exactly what's happening.
The WAR may "seem" to be deployed, when it actually wasn't.
I use JBoss as a container and I got the "...Servlet action is not
available..."
error hundreds of times for any sort of reason (missing classes, etc.).
Some times I also had to restart JBoss altogether...
Bye
Paolo Rizzi
-----Messaggio originale-----
Da: Chris Holmes [mailto:cholmes@anonymised.com]
Inviato: mercoledì 6 aprile 2005 11.46
A: Hampe, Mark
Cc: geoserver-devel@lists.sourceforge.net
Oggetto: Re: [Geoserver-devel] problem: servlet action is not
availableGenerally if everything is working except that web admin tool it
indicates that the jre is working fine and the jdk is messing up.
These computers have the full jdk, right? That would
definitely do it.
But this error message isn't what I would expect. I find it very odd
that you've tried it on three different machines. Maybe build from
source? Or try the binary install? Just to see if you can get it
working at all. Though perhaps there are problems with sun
application
server and struts... that's what the action servlet is for. Do you
need to use the sun one? (yes, we should support it, I'll try to
download and test, but my internet connections are spotty these days).Sorry to not be of more help, this one's kinda stumping me.
Chris
Quoting "Hampe, Mark" <Mark.Hampe@anonymised.com>:
> dear all,
> i have problems installing the geoserver in a sun application server
> environment.
> deploying the war archive is no problem. but when i start the
> geoserver =
> with http:…:8080/geoserver the welcome.do is called and i get the =
> message:
> "The requested resource (Servlet action is not available) is not =
> available." i've tried to install at three different computers
> (linux, =
> w2000, xp) but got the same problem everywhere.
> has anybody an idea what this can be and can help?
> thank you,
> mark
> SF email is sponsored by - The IT Product Guide
> Read honest & candid reviews on hundreds of IT Products from real
> users.
> Discover which products truly live up to the hype. Start
reading now.
> http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
This mail sent through IMP: https://webmail.limegroup.com/-------------------------------------------------------
real users.
Discover which products truly live up to the hype. Start reading now.
