What about providing a default SRS value server-wide???
Something inside the config of GeoServer.
I think most people will only use the very same SRS for all
their tables, so a server-wide value should save client code
most of the time.
Bye
Paolo Rizzi
-----Messaggio originale-----
Da: Gabriel Roldán [mailto:groldan@anonymised.com]
Inviato: martedì 29 novembre 2005 19.54
A: geoserver-devel@lists.sourceforge.net
Cc: Brent Owens; Justin Deoliveira; David Blasby
Oggetto: Re: [Geoserver-devel] Re: about SRS parameterAgreed, we can schedule it for after 1.3.0.
Anyway, note the current behavior is to let it null, not to
use 4326, so I'm
letting it as is, which finally means querying in whatever
the feature source
is in.
Problem is when more than one FS is being queries at the same
time, though.comments?
On Tuesday 29 November 2005 18:48, Brent Owens wrote:
> If we do make this manditory, do we want it for 1.3.0?
> We can always make it pseudo optional. If the SRS is supplie din the
> request, we use it. If it is not supplied, we add in 4326
as a default.
> This will stop client code from breaking. This could result in
> unexpected results however.
> I think we need to look at how long it would take to change, and how
> many other things it will break, in order to determine when
we should
> implement it.
> Brent Owens
> TOPP
> Justin Deoliveira wrote:
> > I guess my only concern is that making the SRS parameter manditory
> > breaks client code that doesn't presently supply the
paramter. Making
> > things optional is much easier then making things mandatory.
> > On the other hand the spec saying it should be manditory
is big hammer
> > to throw around.
> > What does everyone else think.
> > -Justin
> > Gabriel Roldán wrote:
> >> Hi all,
> >> I just created http://jira.codehaus.org/browse/GEOS-493
> >> the question is if you're ok in making SRS parameter mandatory
> >> (that's what the spec says).
> >> Cheers,
> >> Gabriel.
> This SF.net email is sponsored by: Splunk Inc. Do you grep
through log
> files for problems? Stop! Download the new AJAX search
engine that makes
> searching your log files as easy as surfing the web.
DOWNLOAD SPLUNK!
> http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel-------------------------------------------------------
through log files
for problems? Stop! Download the new AJAX search engine that makes
DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
AVVERTENZE AI SENSI DEL D. LGS. 196/2003
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i, sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceveste questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema; costituisce comportamento contrario ai
principi dettati dal D. Lgs. 196/2003 il trattenere il messaggio stesso,
utilizzarlo per finalità diverse.
