R: [GRASS-dev] Re: GUI support for TclTk 8.5
I'd like to see the new version, with warning. Jerry
---- Original message ----
Date: Mon, 10 Mar 2008 13:23:42 +0100
Subject: R: [GRASS-dev] Re: GUI support for TclTk 8.5
To: "GRASS developers list" <grass-dev@lists.osgeo.org>
  Hin
  NVIZ works fine for me, with tcl/tk 8.5.1
  BTW, I just finished the installer for windows, but
  there's still a problem I'm not able to fix:
  installer procedure creates 4 different files to let
  GRASS work even if installed in dirs with spaces;
  files are:
  grass63.bat
  grass63 (to launch grass from msys shell)
  msys.bat
  grassrc6 (to avoid initial location error)
  It works fine, but nviz fails if GRASS is installed
  in a "spaced" dir; I verified that error doesn't
  occur when installed in a "space free" dir!
  I could release it right now (actually, after lunch
  ;-)), warning in the install procedure to not use
  dir with spaces, or delay the release and try to fix
  the problem.
  What do you think about?
  Marco
  Da: grass-dev-bounces@lists.osgeo.org per conto di
  Maris Nartiss
  Inviato: lun 10/03/2008 13.14
  A: GRASS developers list
  Oggetto: Re: [GRASS-dev] Re: GUI support for TclTk
  8.5
  Probably problem is mixed back and forward slashes
  within single call?
  Please, open new ticket for this (hardcoded paths in
  nviz).
  Maris.
  2008/3/10, Paul Kelly
  <paul-grass@stjohnspoint.co.uk>:
  > However, in a bit of further testing this morning
  I've discovered a new
  > error that appears from different sources:
  > couldn't duplicate input handle: bad file number
  > while executing
  > "exec $src_boot/bin/g.gisenv GISBASE"
  > (procedure "Nv_makeGUI" line 13)
  > invoked from within
  > "Nv_makeGUI.top"
  > (file
  "s:/grass/trunk/dist.i686-pc-mingw32\etc\nviz2.2\scripts\nviz2.2_script"
  > line 1025)
  > Paul
  grass-dev mailing list
________________
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
