Hi dear GRASS users:
I am having troubles importing files from idrisi, and hereby securing helps from
you.
I have exported idrisi files using ascii raster format. And then I edited the
file (deleting the first two lines of projection and zone, so there are six
lines as the header). After ftp them to GRASS, I ran r.in.ascii. Everything
looked okay. However, when I tried to display it, it was blank--three or four
non-sense colorful lines at the top, and elsewhere was just white. I checked the
file under cellhd directory. It reads:
proj: 1
zone: 16
north: 4386270
south: 4351770
east: 730110
west: 686490
cols: 1454
rows: 1150
e-w resol: 30
n-s resol: 30
format: 0
compressed: 1
Actually it is in UTM 16, and it is within the current region. I am not sure of
the last sentence. Does it mean that the file is compressed so that GRASS could
not process it correctly?
I also tried to export from idrisi using binary format, which produces two
directories--cell and cellhd, each containing one file of the same name. In
grass I then ran r.support to get a color table for it. However, this time it
was even worse--I couldn't get the file done.
I am stuck. Could someone give me some hints? Thanks a lot in advance.
Houxiang
you.
proj: 1
zone: 16
north: 4386270
south: 4351770
east: 730110
west: 686490
cols: 1454
rows: 1150
e-w resol: 30
n-s resol: 30
format: 0
compressed: 1
Houxiang
Dear Houxiang,
I had also some problems when exchanging maps from Idrisi to Grass but now
it works. I used Idrisi for Windows 1.0 and Grass 4.1.
It is correct to delete the first two line of the Idrisi output-data-file
and to use ASCII-data-format.
I did not use UTM but Transverse Mercator and Geographic projection (proj
3 and 99). I solved my problem by changing the format of east/west and
north/south data. (Idrisi format does not fit Grass format, so errors
occured). So I would suggest check the digits of your input by g.region.
Good luck,
Stephan
Stephan Haverkamp
Institut für Landeskultur
Senckenbergstr. 3 priv.: Grabenstr. 14
D-35390 Giessen 35396 Giessen
Tel.: 0641/99 37384 Tel.: 0641/54470
Fax.: 0641/99 37389
e-mail: Stephan.Haverkamp@agrar.uni-giessen.de
you.
proj: 1
zone: 16
north: 4386270
south: 4351770
east: 730110
west: 686490
cols: 1454
rows: 1150
e-w resol: 30
n-s resol: 30
format: 0
compressed: 1
Houxiang
Dear Houxiang
I have never done importing files from IDRISI to GRASS, but when I tried
import *.tif files into GRASS a problem was occured by current mask at my
location. So try to remove a mask from your location by r.mask.
Good luck,
Rado Bonk
GRASS community-
It seems that my i.fft and i.ifft are not working on my Linux
machine. I am getting a "G_malloc out of memory" error when I try to run
them.
I have compiled these binaries from the 4.1.5 source found on "moon". My
system is Linux 2.0 (Slackware). Most other commands compile and work as
expected.
What's wrong and how might I fix it?
Jeff Hollenbeck
Dept. of Fishery and Wildlife Science
New Mexico State University
jhollenb@nmsu.edu
