r.in.hdf: wrong in grass5beta3
I've used r.in.hdf to import an image
from the VEGETATION instrument of
SPOT4, which come in hdf.
The program runs, but the resulting raster:
1. Has correct size.
2. The image is divided in 4 quarters:
- A 4x inverse zoom appears in the 2 upper quarters
- Blank in the 2 bottom quarters.
I've tried swaping bytes (the hdf come as for PC,
thanks Stephan Eickschen),
but the geometric result is the same.
I suspect that the problem could be that
r.*.hdf libraries are
outdated, I think that these hdf come as V4
(I'm trying to find out) and the grass libraries are
V3.2 release 3.
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
