r.in.hdf: wrong in grass5beta3
I've used r.in.hdf to import an image
from the VEGETATION instrument of
SPOT4, which come in hdf.
The program runs, but the resulting raster:
1. Has correct size.
2. The image is divided in 4 quarters:
- A 4x inverse zoom appears in the 2 upper quarters
- Blank in the 2 bottom quarters.
Hi Agus,
currently I am updating r.in.hdf/r.out.hdf to HDF4.1.3 lib
(the latest). It is not ready yet, sorry. The results from
your file are the same here: The image is divided in 4 quarters.
Perhaps it will be fixes with the new HDF-lib.
Best regards
Thanks, at least we know where the problem is.
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
Hi Agus,
Best regards
