r.in.sunrast
From lists-owner@max.cecer.army.mil Tue Sep 22 18:53:06 1992
Subject: r.in.sunrast
Can somebody please tell me what r.in.sunrast does?
Nalneesh Gaur
[from the manual entry]
     This program converts a SUN raster file that has been
     created by SUN's "screendump" utility to a GRASS raster
     file. Output is placed in the /cell directory under the
     user's current GRASS mapset.
     The program prompts the user to enter the name of the SUN
     raster file to be converted and the name to be assigned to
     the GRASS raster file to contain the resultant image.
     It is recommended that this program be used in an x,y
     database (as opposed to, for example, a UTM data base),
     since the cell header is created with nonsense coordinates
     (i.e., coordinates designed only to specify the number of
     rows and columns in the image). Of course, the user can
     adjust the cell header after import using r.support.
     The user must, of course, first create the SUN raster file
     to be converted, either by running the SUN "screendump"
     utility (to capture a displayed image) or by some other
     means (e.g., from a scanning system that produces SUN raster
     file format).
