I've been trying to convert a sunraster image into the grass format. The
conversion seems to go ok (I'm using the 4.0 updated version of r.in.sunrast)
but when I display the image using d.rast, the image is all white. The
documentation for r.in.sunrast mentions using r.support, but there is no
documentation for r.support.If anybody could tell me what step I'm missing, I would appreciate it.
Brian
_________________--
Brian,
you are doing everything correctly (Ithink). After completing the r.in.sunrast you have to reset the region. use the following command:
g.region rast=rasterfilename
d.erase
d.rast rasterfilename
goodluck
Teresa
