r.in.tiff- problem with import *.tif
On Mon, 8 Dec 1997, Malcolm Williamson wrote:
As none of the graphics import programs are working for you, I'd suggest
checking the following:
1) Make sure no MASK is in place before importing the image.
!!! This was the right solution,I removed mask and it,s OK now!!!
     Thanks, /Malcolm/
> Rado Bonk
2) Set your region to match your newly created raster file:
  g.region rast=name_of_output_of_r.tiff
  d.erase
  d.rast name_of_output_of_r.tiff
3) If the image is grayscale, set the color table to a histogram
equalized gray scale:
  r.colors map=name_of_output_of_r.tiff color=grey.eq
One of these steps will most likely take care of your problem. Good luck,
  -Malcolm Williamson
On Mon, 8 Dec
1997, Radoslav Bonk wrote:
> Hello to all GRASS users
> As I wrote,during working with r.in.tiff for orthorectification of
> aerial photos i had no problems. They just appeared under Linux Red Hat
> 4.2/GRASS 4.1.3. The problem is that it,s not possible to visualize any
> cell file which origin from *.tiff file.
> Import through r.in.tiff seems to be OK, all cell directories are also
> OK, but on the monitor always appears only a white field, and after
> d.what.rast there is "no data".
> I think there is only necesary switch "something" and problem will be
> solved,maybe something with color pallete.
> I will be happy for every good idea,
> Thanks to all
> Rado Bonk
> PS: the same problem is with r.in.gif
> r.in.sunrast
> Radoslav Bonk
> Comenius University,Faculty of Natural Sciences
> Department of Physical Geography and Geoecology
> Mlynska Dolina 842 14,Bratislava SLOVAKIA
> e-mail: bonk@nic.fns.uniba.sk
> PRIVAT: Svinia 221, 082 32; tel:+421/91/958 187
