r.in.tiff woes.
Good afternoon,
   A bug has seemed to pop up in grass now, that was not there before. I had
previously used r.in.tiff without any problems, but now am running into
Memory fault - core dumped... Somewhat puzzling. Here's what happens, even
though identical runs used to work fine...
GRASS-GRID > r.in.tiff input=jello.tif output=blah
( d.rast blah works fine on the raster file "blah" )
GRASS-GRID> ls -l core
-rw-r--r-- 1 franklin 8507824 Jun 14 14:51 core
Has anyone seen this before?
Here is the verbose output of r.in.tiff:
> r.in.tiff -v input=jello.tif output=blah
Reading jello.tif...TIFF Directory at offset 0xb15a
  Image Width: 256 Image Length: 192
  Bits/Sample: 8
  Compression Scheme: Macintosh PackBits encoding
  Photometric Interpretation: palette color (RGB from colormap)
  Orientation: row 0 top, col 0 lhs
  Samples/Pixel: 1
  Rows/Strip: 32
  Planar Configuration: single image plane
  Color Map: (present)
  6 Strips:
      0: [ 8, 7260]
      1: [ 7268, 7700]
      2: [ 14968, 7736]
      3: [ 22704, 7873]
      4: [ 30577, 6573]
      5: [ 37150, 8252]
256x192x8 image
8 bits/sample, 1 samples/pixel
256 colormapped
Creating SUPPORT Files for blah
done.
I hope someone has run into this problem before...
   Steve Franklin
   franklin@ug.cs.dal.ca
