Hello,
I'm wondering for that behavior in the r.le.setup programm:
If I will built up regions, I press the number in the menue and then
nothing happens... only CTRL-C will bring me back.
Another question:
I can't calculate the fractal-dimension with the fra=f1 option in
r.le.patch. My resulting map is only a map showing zero.
r.le.dist don't work, segmentation fault.
My system is a SUSE 6.0 with grass 4.2.1 V21
Thanks in advance.
Dieter
__________________________________
Dieter Lehmann
Institut für Angewandte Forschung
Fachhochschule Nürtingen
Schelmenwasen 4-8
Tel. 07022/404 192
Fax. 07022/404 166
