r.mapcalc and the neighborhood modifier
is there an available example of r.mapcalc that uses the
neighborhood modifier, so that the result of the target
cell depends on the weighted values of the 8 surrounding
cells ?
if there is could i get a copy ?
Tom Nelson
C.O.E.
Fort Worth, Texas
Maybe this is a little complex example but this a shell script that I
wrote a year ago when was testing different neighbourhood operators.
This script does a distance weighting on the surrounding pixels. The
same methodolgy can be used with 8 or more neighbors. I wrote another
version that used 8 neighbors as well, but that script is still in
Grass 3.1 version. Well I will include that script as well in the
end. But be aware of that the second script is a 3.1 version.
The setting of the discrimination value is a little tricky. Please
read the original article if you want to use this script.
I have not used this script very much so I would be glad for
comments if you find bugs. As input you should use maps in nominal
or ordinal scale (i.e. classed data ). Do not run this on a map
with too many categories since this will create a very big rulefile
for r.mapcalc.
Have fun !!!
Lars
Lars Schylberg Email: larss@fmi.kth.se (Internet)
Department of Photogrammetry larss@sekth.bitnet (Bitnet)
Royal Institute of Technology Tel. +46 8 790 86 33 (office)
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
r.prox4.sh
#!/bin/sh
# r.prox4.sh ( version 1.0 )
# Neighbourhood filter based on selecting the level of influence
# exerted on the central pixel by a predetermined set of nearest
# neighbors, uses a proximity function derived by analogy from
# a gravitational attractive force model
# This version is based on the article:
# I.L. Thomas (1980), Spatial Postprocessing of Spectrally
# Classified Landsat Data, Photogrammetric Engineering and
# Remote Sensing, Volume 46, No 9, pp 1201-1206
# This version uses a 4 neighbourhood around the center pixel as
# in the original paper.
# Author: Lars Schylberg 910522
# Department of Photogrammetry, KTH, Stockholm
# email: larss@fmi.kth.se
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
# Evaluate arguments
if [ $# != 3 ]
then
    echo
    echo Usage: `basename $0`
    echo ' input=mapname '
    echo ' output=mapname '
    echo ' dis=level of discrimination ( read the article for help ) '
    echo
    echo ' This program does a neighborhood clean up operation'
    echo ' based on a proximity function. The discrimination value'
    echo ' determines how much that is removed'
    echo
    exit 1
fi
# parse input arguments
for i do
  case $i in
    input=*)
      IN=`echo $i | sed s/input=//` ;;
    output=*)
      OUT=`echo $i | sed s/output=//` ;;
                dis=*)
                        DIS=`echo $i | sed s/dis=//` ;;
      echo ""
      echo "Unrecognized option: $i"
      echo 'Options: input=mapname '
                        echo ' dis=value'
      exit 1
  esac
done
# Check the input arguments
eval `g.findfile element=cell file=$IN`
if [ ! "$file" ]
then
    echo "$IN - cell file not found"
    exit 2
fi
eval `g.findfile element=cell file=$OUT`
if [ "$file" ]
then
    echo "$OUT - exists already"
    exit 2
fi
echo
echo 'Working ...'
nsres=`g.region -p raster=$IN | awk -f: '{ if (NR==7) print $2 }'`
ewres=`g.region -p raster=$IN | awk -f: '{ if (NR==8 ) print $2 }'`
d25=$nsres
d85=$nsres
d45=$ewres
d65=$ewres
r.stats -cqz $IN | awk '{print $1}' > categories
# Create rule for mapcalc
echo $OUT '= \
eval( \' > rulefile
for i in `cat categories`
do
echo '\
q2 = eval( qt = eval( if( '$IN'[-1,0] == '$i' )) , qt * 2.0 ) ,\
q25 = eval( if( '$IN'[0,0] == '$i' && '$IN'[-1,0] == '$i', 2.0, 1.0)) ,\
q4 = eval( qt = eval( if( '$IN'[0,-1] == '$i' )) , qt * 2.0 ) ,\
q45 = eval( if( '$IN'[0,0] == '$i' && '$IN'[0,-1] == '$i', 2.0, 1.0)) ,\
q6 = eval( qt = eval( if( '$IN'[0,1] == '$i' )) , qt * 2.0 ) ,\
q65 = eval( if( '$IN'[0,0] == '$i' && '$IN'[0,1] == '$i', 2.0, 1.0)) ,\
q8 = eval( qt = eval( if( '$IN'[1,0] == '$i' )) , qt * 2.0 ) ,\
q85 = eval( if( '$IN'[0,0] == '$i' && '$IN'[1,0] == '$i', 2.0, 1.0)) ,\
f'$i' = eval(((q2 * q25)/('$d25'.0 *'$d25'.0)) + ((q4 * q45)/('$d45'.0 *'$d45'.0)) + \
((q6 * q65)/('$d65'.0 *'$d65'.0)) + ((q8 * q85)/('$d85'.0 *'$d85'.0)) ) , \' \
>> rulefile
done
echo 'fmax = max( \'>> rulefile
do
echo 'f'$i' ,\'>> rulefile
done
echo '0 ) ,\'>> rulefile
echo 'fc = 0 ,\'>> rulefile
echo 'fclass = max( \'>> rulefile
do
echo 'eval( if( fmax == f'$i', '$i' )) ,\'>> rulefile
done
echo '0), \'>> rulefile
echo 'if( fmax < '$DIS', fclass, '$IN'[0,0] )\
'>> rulefile
# Run mapcalc
cat rulefile | r.mapcalc
# set a nice colortable to the outputfile, the same as the input file
cp $LOCATION/colr/$IN $LOCATION/colr/$OUT
cp $LOCATION/cats/$IN $LOCATION/cats/$OUT
# Clean up
/bin/rm rulefile
/bin/rm categories
Gprox8.sh
#!/bin/sh
# Gprox8.sh ( version 1.0 )
# This version uses a 8 neighbourhood around the center pixel
# Department of Photogrammetry, KTH, Sweden
# Input arguments:
# $1 : filename of input cell file
# $2 : filename of output cell file
# $3 : level of discrimination ( try 0.0012 if you don't know, for 5 m cells)
case $# in
0) echo 'Usage: '$0' input result discrim '; exit 2;;
1) echo 'Usage: '$0' input result discrim'; exit 2;;
2) echo 'Usage: '$0' input result discrim'; exit 2;;
3) ;;
*) echo 'Usage: '$0' input result discrim '; exit 2;;
esac
# Test if input file is exists
if test ! -f $LOCATION/cell/$1
then
    echo 'File ' $LOCATION/cell/$1 ' not found'
    exit 2
fi
# Test if result file is exists
if test -f $LOCATION/cell/$2
then
    echo 'File ' $LOCATION/cell/$2 ' exists already'
    exit 2
fi
echo
echo 'Working ...'
nsres=`Gwindow - layer=$1 print | awk -f: '{ if (NR==7) print $2 }'`
ewres=`Gwindow - layer=$1 print | awk -f: '{ if (NR==8 ) print $2 }'`
d25=$nsres
d85=$nsres
d45=$ewres
d65=$ewres
d15=`echo $ewres $nsres | awk '{printf "%.2f\n",exp(log(($1*$1)+($2*$2))*0.5)}'`
d35=$d15
d75=$d15
d95=$d15
dis=$3
echo $2 '= \
eval( \' > rulefile
for i in `Gstats -cz $1 | awk -f: '{print $1}'`
do
echo '\
q5 = eval( qt = eval( if( '$1'[0,0] == '$i' )) , qt * 2 ) ,\
q2 = eval( qt = eval( if( '$1'[-1,0] == '$i' )) , qt * 2 ) ,\
q4 = eval( qt = eval( if( '$1'[0,-1] == '$i' )) , qt * 2 ) ,\
q6 = eval( qt = eval( if( '$1'[0,1] == '$i' )) , qt * 2 ) ,\
q8 = eval( qt = eval( if( '$1'[1,0] == '$i' )) , qt * 2 ) ,\
q1 = eval( qt = eval( if( '$1'[-1,-1] == '$i' )) , qt * 2 ) ,\
q3 = eval( qt = eval( if( '$1'[-1,1] == '$i' )) , qt * 2 ) ,\
q7 = eval( qt = eval( if( '$1'[1,-1] == '$i' )) , qt * 2 ) ,\
q9 = eval( qt = eval( if( '$1'[1,1] == '$i' )) , qt * 2 ) ,\
f'$i' = eval( ((q2 * q5)/('$d25' *'$d25')) + ((q4 * q5)/('$d45' *'$d45')) + \
((q6 * q5)/('$d65' *'$d65')) + ((q8 * q5)/('$d85' *'$d85')) + \
((q1 * q5)/('$d15' * '$d15')) + ((q3 * q5)/('$d35' * '$d35')) + \
((q7 * q5)/('$d75' * '$d75')) + ((q9 * q5)/('$d95' * '$d95')) ) , \' \
>> rulefile
done
do
done
do
done
echo 'if( fmax > '$dis', fclass ) \
'>> rulefile
# Run mapcalc
Gmapcalc2 < rulefile
eval `gisenv`
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
cp $LOCATION/colr/$1 $LOCATION/colr/$2
cp $LOCATION/cats/$1 $LOCATION/cats/$2
# Clean up
#/bin/rm rulefile
for r.mapcalc.
Have fun !!!
Lars
r.prox4.sh
#!/bin/sh
if [ $# != 3 ]
then
    echo
    echo
    echo
    exit 1
fi
for i do
  case $i in
    input=*)
    output=*)
                dis=*)
      echo ""
                        echo ' dis=value'
      exit 1
  esac
done
if [ ! "$file" ]
then
    exit 2
fi
if [ "$file" ]
then
    exit 2
fi
echo
echo 'Working ...'
d25=$nsres
d85=$nsres
d45=$ewres
d65=$ewres
echo $OUT '= \
eval( \' > rulefile
do
echo '\
>> rulefile
done
do
done
do
done
'>> rulefile
# Run mapcalc
# Clean up
/bin/rm rulefile
/bin/rm categories
Gprox8.sh
#!/bin/sh
# Input arguments:
case $# in
3) ;;
esac
then
    exit 2
fi
then
    exit 2
fi
echo
echo 'Working ...'
d25=$nsres
d85=$nsres
d45=$ewres
d65=$ewres
d35=$d15
d75=$d15
d95=$d15
dis=$3
echo $2 '= \
eval( \' > rulefile
do
echo '\
>> rulefile
done
do
done
do
done
'>> rulefile
# Run mapcalc
eval `gisenv`
# Clean up
#/bin/rm rulefile
