r.mapcalc problem
Hi
I have been trying to use r.mapcalc to calculate a new layer based on several
other map layers. The following is the script for r.mapcalc
1000.2.lfc = eval( \
  b=(sin(1000.2.slp)/0.0896)/(3.0*exp(sin(1000.2.slp),0.8)+0.56),\
  mine = b/(1+b),\
  x = 1000.2.lng/22.13,\
  if(mine,exp(x,mine)))
when this script is run with r.mapcalc i get a POW domain error. After some
chasing after the error I seem to have tracked it to the exp expression in the
last line. If I replace the variable mine with a fixed value in the exp expression I nolong get the error.
The range of *.slp is 0-12 and *.lng is 0-900. x, therefore could be 0 and mine can be zero also, although the use of the if should limit the use of exp to +ve values of mine.
Any ideas on why this is working this way?
Thanks
Steve Huddle, Graduate Student
School of Engineering, University of Guelph, Guelph, ON, Canada, N1G 2W1
E-Mail InterNet: HUDDLE@Net2.EOS.UoGuelph.Ca
Telephone: (519) 824-4120 ext 4323 FAX: (519) 836-0227
