If I type
set ima = vegetation1
r.mapcalc res = $ima * $imar.mapcalc works without problems, but if I type
r.mapcalc < testwhere test is a file whose only line is:
res = $ima * $ imathen r.mapcalc says <$ima> not found, that is, it does not interpret
$ima as the value of ima. If I write test as,
'res = ' $ima '*' $imathen r.mapcalc gets confused and me too.
I have to use this piping because r.mapcalc is within a loop in an
script, ima takes different values and the expression actually passed
to r.mapcalc is complex.
Is there any way to get r.mapcalc to interpret $ima when piped?Thamks,
Agus
Try :
r.mapcalc <<EOI
res = $ima * $ima
EOI
or
r.mapcalc "res = $ima * $ima "
Both forms should work.
Bob Courtney
Atlantic Geoscience Center
