Darrell:
I lost the intent of the original message. Were you going to try to export a raster file into a file in just an x, y and z format so that it could be used? If so, I'm all for it. (Then GNUPLOT could use it, right???).
Go for it,
Shane.
amante@grouse.pnl.gov (amante@grouse.pnl.gov) writes on 26 Oct 93:
Craig was trying to put info into something else.
Actually, for g.gnuplot, the following works well (you have to insert a few blank lines).
r.stats -1x $1 | awk '$2 != row{print "";row=$2}{print}'
--Darrell
P.S. you may want to reduce your resolution (g.region), depending.
