--------- Announcement ------------
I have placed a new script called "r.proj" at
ftp://moon.cecer.army.mil/grass/incoming/r.proj
This is a none-too-swift script which combines
"r.stats", Gerry Evenden's "proj" and Darrell McCauley's "s.sample"
to copy a cell/raster map from one location to another, doing
the necessary re-projection.
I have tested it only a bit so it may fall over occasionally.
In particular, I've only tested a couple of different projections.
I offer this "as-is" in case it can help anyone.
Feedback welcome, but maintenance will only be on an
as-needs basis - I'm not into software engineering here!
Good Luck Simon Cox
_________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 284 8443 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
simon@ned.dem.csiro.au W
AGCRC info>> http://www.ned.dem.csiro.au/AGCRC/
