r.proj - Wishes come true!!!
Yes I have a program called r.proj which will work like v.proj, however,
I donot have a clean man page for it. Further, it needs mapgen properly
installed (v.proj also requires mapgen). Once you ran the r.proj, I have
another program called r.neigh a modified version of r.neighbor which fills
any holes that was not filled while running r.proj either using mode or average
method depeneding on the type of layer. This version of r.neigh modifies only
those cells that are null data or no data.
I will put both the programs in anonymous ftp site
brcsun1.tamu.edu
under pub/outgoing/srin
called r.proj.tar and r.neigh.tar
Thanks very much, Srin. I look frward to trying out the programs.
Mike Hill
Michael J Hill
Research Scientist
CSIRO Pastoral Research Laboratory, Armidale, NSW, Australia,2350.
E-Mail address: mhill@chiswick.anprod.csiro.au
