R: R: R: R: [Geoserver-devel] R: Geoserver Enterprise
> So it seems we two are quite aligned, I too like Spring and JBoss!!!
> I did many test with Spring a few months ago, and almost
decided to use it,
> but then abandoned it in favor of JBoss, because we already
decided to use
> it
> as our application server, so there was no point in using
yet another
> library (Spring).
From what I can tell, the main reason for chosing one over
the other at
this time is political.
I often read that JBoss has some "politacal" drawbacks, some people
even write it like this: "JBo$$", but I really never understood why.
It has financially powerful sponsors, but the same is true for Eclipse.
I don't know, it has a strange kind of licence???
> From what I've seen so far I can tell that the IoC
container of Spring is
> much more poweful and developed, but JBoss' Microcontainer
will soon reach
> it.
> Aspect programming is a great thing. I did some tests
months ago with both
> the Spring aspect framework and JBossAOP. They follow different
> philosophies,
> but I found JBossAOP to be much more powerful.
I have looked at SpringAOP so I cant comment, but I am intrigued and
intend to look at JBossAOP.
I looked at AOP about one year ago, so things may have changed,
but the main difference was that SpringAOP works like the standard
Java Proxy class, so you have to explicitely "aspectize" each object
instance you intend to work upon. JBossAOP instead works with code-weaving,
so you can declaratively aspectize whatever instance of a given class
(you can do much more than that).
For example you can write somthing like this in a XML file:
  <bind
pointcut="execution($instanceof{org.geotools.data.DataStore}->new(..))">
to have an aspect called whenever a DataStore is created by whatever code
inside the same JVM. Even if your program is a simple Java main() one,
you can run it with the "-javaagent" parameter to have it instrumented
by Java (maybe it works only with Java 1.5, I don't remember).
> Anyway I'm not pushing JBoss, I just want to be sure that
each option
> is taken into account. I like Spring very much, so I'd be
happy if it
> would be chosen. It just seems to be less "enterprise" than JBoss...
I dont really like the name Geoserver "Enterprise". The term
"Enterprise" brings along a lot of preconceptions with it that dont
apply. For instance Enterprise in the java world means that you are
using J2EE, and you dont have to with Spring or JBoss Micro.
Furthermore, our conversations about the architecture seem to
be shaping
geoserver into a much smaller core, with a wealth of services and
utilities "plugged into it". Enterprise software is notorious
for being
very monolithic.
All that being said I am not a marketing consultant so who knows, I
would like to bring the name out for public debate as well.
I like the "GeoServer Enterprise" name, it gives me exactly the kind
of confidence in robustness, reliability, etc. that I need,
but I do agree that it may sound negative to others.
      Bye Paolo
> Bye
> Paolo Rizzi
> P.S: Can you put up a polling form on the Wiki, or
something like that???
> Because EMail tends to go missing, after a while...
This is a great idea, I am going to look into this.
Justin
>>Spring)
>>I must say I am leaning pretty heavily toward Spring, for a
couple of
>>reasons:
>>1) It is fully featured web application framework
>>2) WebMVC is a nice substitute for struts
>>3) It is integratable with pretty much of the other web
>>technologies out
>>there, including struts
>>4) I have found aspects to be a very nice way of organizing code
>>However my number one reason for liking Spring is the
>>popularity it is
>>gaining. For instance, this year at OOPSLA Spring received
>>much attention.
>>JBoss Microcontainer)
>>I eagerly await the full evaluation, I have done some
>>research, here are
>>my thoughts.
>> From what I can tell JBoss MicroContainer offers everything
>>that Spring
>>does. However it still seems like JBoss Microcontainer is
>>still the new
>>guy on the scene and most people are still using spring.
>>This is an article comparing the two:
>>http://www.javalobby.org/java/forums/t49723.html
>>Here is an interesting post that referes to JBoss licencing:
>>http://www.javalobby.org/java/forums/m91945483.html
>>So all in all I would have to say that my choice at this moment is
>>definitly Spring.
>>Any one else who has an opinion please chime in.
>>-Justin
>>P.Rizzi Ag.Mobilità Ambiente wrote:
>>>I looked at:
>>> http://docs.codehaus.org/display/GEOS/GeoServer+2.0+Technology
>>>and saw you updated it with more detailed information, very
>>good work!!!
>>>I'm experimenting a bit with JBoss Microcontainer and I
>>hope to be able
>>>to add my experiments' results to the page soon.
>>>I think we should start a sort of opinion poll.
>>>Obviously you are free to decide as you like, but I think that
>>>any "Humble and Biased" opinion, can be useful anyway.
>>>So, here follows mine (please imagine an implicit "I think..."
>>>before each affirmation).
>>>Bye
>>>Paolo Rizzi
>>>.) OSGi
>>>It's surely powerful, but not easily "embeddable".
>>>It tends to want having things done in its own manner
>>>and it may conflict with other container (J2EE in particular).
>>>--- I'd not use it. ---
>>>.) Geronimo / GBeans
>>>Light, flexible and embeddable enough, but it has nothing more
>>>than JBoss / Microcontainer has, and it's not enough mature.
>>>.) Spring
>>>Very light, flexible and embeddable. It's designed to integrate,
>>>not to conflict, with other containers and technology.
>>>It optionally offers more than the plain container (MVC,
AOP, etc.).
>>>It's quite mature and supported, but maybe there're not many people
>>>"behind" it, apart from its creator.
>>>--- I'd use it. ---
>>>.) JBoss / Microcontainer
>>>Very light and flexible. The new Microcontainer is embeddable
>>>and it's designed to integrate, not to conflict, with other
>>containers.
>>>JBoss optionally offers a lot more than the plain container
>>(MVC, AOP,
>>>etc.).
>>>It's very mature and supported, and there's a strong
>>support "behind" it.
>>>--- I'd use it. ---
>>>Licenses details remains to be looked for (but I'm no
>>expert in this).
>>>In the end I'd use JBoss / Microcontainer, because that's
>>what I've used
>>>till now (JBoss, not the Microcontainer).
>>>If for any reason this is judged not to be usable, I'd use Spring.
>>>I see no reason to use Geronimo / GBeans instead of JBoss /
>>Microcontainer.
>>>I'd not use OSGi anyway.
>>>>-----Messaggio originale-----
>>>>Da: Justin Deoliveira [mailto:jdeolive@anonymised.com]
>>>>Inviato: lunedì 24 ottobre 2005 17.04
>>>>A: "P.Rizzi Ag.Mobilità Ambiente"
>>>>Cc: 'dblasby@anonymised.com'; Gabriel Roldán; "L.Percich
Ag.Mobilità
>>>>Ambiente"; geoserver-devel@lists.sourceforge.net
>>>>Oggetto: Re: R: [Geoserver-devel] R: Geoserver Enterprise
>>>>Hi Paolo,
>>>>I am glad you are interested in this topic. A technology
>>has not yet
>>>>been decided on, still in the evaluation stage. OSGi is just
>>>>the first
>>>>one that I have had time to document. Next I plan to evaluate
>>>>Geronimo.
>>>>Please feel free to add JBoss to the list of candidates. It
>>>>you have the
>>>>time I would love if you could write some docs about why you
>>>>think its a
>>>>good way to go.
>>>>The list of technologies on the page is by no means complete
>>>>so please
>>>>add anything else you think should be there.
>>>>-Justin
>>>>>>Inviato: venerdì 30 settembre 2005 19.20
>>>>>>We are in the process of putting up some wiki space
>>>>dedicated to the
>>>>>>design. It would be nice to start refining some of the great
>>>>>>discussions
>>>>>>that have been going on with OpenSDI and some of things you
>>>>guys have
>>>>>>been doing over the last little while into a architecure and
>>>>>>high level
>>>>>>design.
>>>>>>Justin
>>>>>Sorry for disappearing in the last weeks, but I've been taken
>>>>>away with exporting data to remote Oracle instances...!!!
>>>>>I looked in the "RnD" Wiki space of GeoServer and saw the:
>>>>>page, that seems the most recently updated.
>>>>>The only technology actually analized in depth is OSGi,
>>>>>does it means you already choose it, or simply is it the
first one
>>>>>you addressed???
>>>>>I'd like to add JBoss as a suitable technology, and also a couple
>>>>>of other considerations. May I edit the page???
>>>>>I'm very interested in the proceeding of this and expecially in
>>>>>Dave's sentence:
>>>>> "...ps. from the last meeting, it appears the "data/catalog"
>>>>> portion of the framework will be somewhat like an expanded
>>>>>"DataEngine"
>>>>> (from the IRC meeting)...".
>>>>>I found no reference to this in the Wiki though... Where
>>>>can I find it???
>>>>>Bye
>>>>>Paolo Rizzi
>>>>>>>>I read the transcript from yesterday's IRC meeting. Sorry
>>>>>>we couldnt
>>>>>>>>attend.
>>>>>>>I'm sorry, because we probably didn't advertised the IRC
>>enough...
>>>>>>>>For the last 2 weeks, I have been in Victoria talking with
>>>>>>the two new
>>>>>>>>TOPP employees (Brent Owens and Justin Deoliveira).
>>>>>>>>We have been discussing a large number of topics, but one
>>>>>>of the major
>>>>>>>>discussions has been on the Geoserver Enterprise Edition.
>>>>>>>>This is basically a new plug-in and extension-point based
>>>>system for
>>>>>>>>doing Geo-based web application (including things like WFS
>>>>>>and WMS and
>>>>>>>>WCS). And "customizing" existing applications. For
>>>>>>example, the SIS
>>>>>>>>stuff "plugging in" to WFS, and geo-wiki things. The new
>>>>Enterprise
>>>>>>>>edition will take geoserver from an application to a
>>platform for
>>>>>>>>developing and customizing web-based geo-applications.
>>>>>>>>We have discussed how we would provide services for most of
>>>>>>>>what's been
>>>>>>>>talked about on the mailing list and the few IRC
>>>>meetings. I think
>>>>>>>>you're going to be very excited about it. We are going to
>>>>>>>>write up our
>>>>>>>>ideas for next week and hope to get some feedback from you.
>>>>>>>Great!!! I'll wait to see what you came up with with much
>>>>>>interest!!!
>>>>>>>>dave
>>>>>>> Bye Paolo
>>>>>>>>portion of the
>>>>>>>>framework will be somewhat like an expanded "DataEngine"
>>>>>>(from the IRC
>>>>>>>>meeting).
>>>>>>>I feel this is fundamental, so I'm happy to know we're
>>>>>>quite tuned on it!!!
>>>>>>>AVVERTENZE AI SENSI DEL D. LGS. 196/2003
>>>>>>>Le informazioni contenute in questo messaggio di posta
>>>>>>elettronica e/o nel/i
>>>>>>>file/s allegato/i, sono da considerarsi strettamente
>>>>>>riservate. Il loro
>>>>>>>utilizzo è consentito esclusivamente al destinatario del
>>>>>>messaggio, per le
>>>>>>>finalità indicate nel messaggio stesso. Qualora riceveste
>>>>>>questo messaggio
>>>>>>>senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>darcene notizia
>>>>>>>via e-mail e di procedere alla distruzione del
messaggio stesso,
>>>>>>>cancellandolo dal Vostro sistema; costituisce comportamento
>>>>>>contrario ai
>>>>>>>principi dettati dal D. Lgs. 196/2003 il trattenere il
>>>>>>messaggio stesso,
>>>>>>>divulgarlo anche in parte, distribuirlo ad altri soggetti,
>>>>>>copiarlo, od
>>>>>>>utilizzarlo per finalità diverse.
>>>>>>>This SF.Net email is sponsored by:
>>>>>>>Power Architecture Resource Center: Free content,
>>>>>>downloads, discussions,
>>>>>>>and more. http://solutions.newsforge.com/ibmarch.tmpl
>>>>>>>_______________________________________________
>>>>>>>Geoserver-devel mailing list
>>>>>>>Geoserver-devel@lists.sourceforge.net
>>>>>>>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
>>>>>>Justin Deoliveira
>>>>>>The Open Planning Project
>>>>>>http://topp.openplans.org
>>>>riservate. Il loro
>>>>messaggio, per le
>>>>questo messaggio
>>>>darcene notizia
>>>>>via e-mail e di procedere alla distruzione del messaggio stesso,
>>>>contrario ai
>>>>messaggio stesso,
>>>>copiarlo, od
>>>>>This SF.Net email is sponsored by the JBoss Inc.
>>>>>Get Certified Today * Register for a JBoss Training Course
>>>>>Free Certification Exam for All Training Attendees Through
>>>>End of 2005
>>>>>Visit http://www.jboss.com/services/certification for more
>>>>information
>>>>Justin Deoliveira
>>riservate. Il loro
>>messaggio, per le
>>questo messaggio
>>darcene notizia
>>contrario ai
>>messaggio stesso,
>>copiarlo, od
>>Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i, sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceveste questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
cancellandolo dal Vostro sistema; costituisce comportamento contrario ai
principi dettati dal D. Lgs. 196/2003 il trattenere il messaggio stesso,
Quoting "P.Rizzi Ag.Mobilità Ambiente" <paolo.rizzi@anonymised.com>:
JBoss!!!
> decided to use it,
> decided to use
> > it
> yet another
> > library (Spring).
> the other at
Eclipse.
I don't think the license is strange, it's lgpl through and trhough as
far as I know. As for powerful financial sponsers, IBM handled eclipse
a lot better - they initially supported it, and still do a lot, but
when it took on a life of its own they rolled out the eclipse
foundation, a not for profit to control it. Many people prefer to have
a non-profit behind an open source project, to make sure that one
organization does not try to monopolize the value. But it's an open
question, for sure.
> will soon reach
> > it.
> > philosophies,
and
code-weaving,
  <bind
code
one,
instrumented
> each option
> happy if it
JBoss...
> be shaping
> for being
> very monolithic.
The GeoServer Enterprise Edition name came up as kind of a joke, to
emphasize to business people that it's as good as other commercial
products out there. But there is some good value in doing that, and I
think we should use it in some capacity, when we make pushes outside
the open source world, attract more traditional gis users (something
I'm hoping to do in the next year). What I like is the idea of
'distributions', and I think one of the distributions should be
'enterprise edition', with lots of bells and whistles. I think we
should come up with a name for the core container geotools catalog+web
component, that can be a base for lots of other services and
deployments. Enterprise edition will be the one distributed as an ear
instead of a war, for example.
Feel free to suggest names for the core, and we can make use of the EE
label at some later date.
Chris
      Bye Paolo
> > Bye
> > Paolo Rizzi
> Justin
> >>Spring)
> couple of
> >>reasons:
> >>technologies out
> >>popularity it is
> >>much attention.
> >>research, here are
> >>my thoughts.
> >>that Spring
> >>still the new
is
> >>definitly Spring.
> >>-Justin
> >>>I looked at:
> >>good work!!!
> >>hope to be able
> >>>Bye
> >>>Paolo Rizzi
> >>>.) OSGi
> >>>.) Spring
> AOP, etc.).
people
> >>>--- I'd use it. ---
> >>containers.
> >>(MVC, AOP,
> >>>etc.).
> >>>--- I'd use it. ---
> >>expert in this).
> >>what I've used
Spring.
> >>Microcontainer.
> Ag.Mobilità
> >>>>Hi Paolo,
> >>has not yet
> >>>>the first
> >>>>Geronimo.
> >>>>you have the
> >>>>think its a
> >>>>good way to go.
> >>>>so please
> >>>>-Justin
> >>>>dedicated to the
> >>>>>>discussions
> >>>>guys have
> >>>>>>high level
> >>>>>>design.
> >>>>>>Justin
> first one
> >>>>>you addressed???
couple
in
> >>>>>Dave's sentence:
> >>>>>"DataEngine"
> >>>>can I find it???
> >>>>>Bye
> >>>>>Paolo Rizzi
> >>>>>>we couldnt
> >>>>>>>>attend.
> >>enough...
> >>>>>>the two new
> >>>>>>of the major
> >>>>system for
> >>>>>>and WMS and
> >>>>>>example, the SIS
> >>>>Enterprise
> >>platform for
> >>>>>>>>what's been
> >>>>meetings. I think
> >>>>>>>>write up our
> >>>>>>interest!!!
> >>>>>>>>dave
> >>>>>>> Bye Paolo
> >>>>>>>>portion of the
> >>>>>>(from the IRC
> >>>>>>>>meeting).
> >>>>>>riservate. Il loro
> >>>>>>messaggio, per le
> >>>>>>questo messaggio
> >>>>>>darcene notizia
> messaggio stesso,
> >>>>>>contrario ai
> >>>>>>messaggio stesso,
> >>>>>>copiarlo, od
> >>>>>>Justin Deoliveira
> >>>>riservate. Il loro
> >>>>messaggio, per le
> >>>>questo messaggio
> >>>>darcene notizia
stesso,
> >>>>contrario ai
> >>>>messaggio stesso,
> >>>>copiarlo, od
> >>>>End of 2005
> >>>>information
> >>>>Justin Deoliveira
> >>riservate. Il loro
> >>messaggio, per le
> >>questo messaggio
> >>darcene notizia
> >>contrario ai
> >>messaggio stesso,
> >>copiarlo, od
> >>Justin Deoliveira
> riservate. Il loro
> messaggio, per le
> questo messaggio
> darcene notizia
> contrario ai
> messaggio stesso,
> copiarlo, od
> Justin Deoliveira
e/o nel/i
loro
per le
messaggio
notizia
ai
stesso,
od
Tame your development challenges with Apache's Geronimo App Server.
Download
it for free - -and be entered to win a 42" plasma tv or your very own
Sony(tm)PSP. Click here to play: http://sourceforge.net/geronimo.php
This mail sent through IMP: https://webmail.limegroup.com/
I like the idea of coming up with a name for the core technology, and then calling an assembly of components "Enterprise". Similar to the relationship between Eclipse and Websphere IDE.
Justin
JBoss!!!
decided to use it,
decided to use
it
yet another
library (Spring).
the other at
Eclipse.
question, for sure.
will soon reach
it.
philosophies,
and
code-weaving,
<bind
code
one,
instrumented
each option
happy if it
JBoss...
be shaping
for being
very monolithic.
Chris
    Bye Paolo
Bye
Paolo Rizzi
Justin
Spring)
couple of
reasons:
technologies out
popularity it is
much attention.
research, here are
my thoughts.
that Spring
still the new
is
definitly Spring.
-Justin
I looked at:
good work!!!
hope to be able
Bye
Paolo Rizzi
.) OSGi
.) Spring
AOP, etc.).
people
--- I'd use it. ---
containers.
(MVC, AOP,
etc.).
--- I'd use it. ---
expert in this).
what I've used
Spring.
Microcontainer.
Ag.Mobilità
Hi Paolo,
has not yet
the first
Geronimo.
you have the
think its a
good way to go.
so please
-Justin
dedicated to the
discussions
guys have
high level
design.
Justin
first one
you addressed???
couple
in
Dave's sentence:
"DataEngine"
can I find it???
Bye
Paolo Rizzi
we couldnt
attend.
enough...
the two new
of the major
system for
and WMS and
example, the SIS
Enterprise
platform for
what's been
meetings. I think
write up our
interest!!!
dave
    Bye Paolo
portion of the
(from the IRC
meeting).
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
messaggio stesso,
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
stesso,
contrario ai
messaggio stesso,
copiarlo, od
End of 2005
information
Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
e/o nel/i
loro
per le
messaggio
notizia
ai
stesso,
od
Download
Tame your development challenges with Apache's Geronimo App Server. Download
Justin Deoliveira
decided to use it,
decided to use
it
yet another
library (Spring).
From what I can tell, the main reason for chosing one over the other at this time is political.
will soon reach
it.
philosophies,
I have looked at SpringAOP so I cant comment, but I am intrigued and intend to look at JBossAOP.
  <bind
I agree, this does look like a much more powerful aspect implementation. More similar to AspectJ.
each option
happy if it
I dont really like the name Geoserver "Enterprise". The term "Enterprise" brings along a lot of preconceptions with it that dont apply. For instance Enterprise in the java world means that you are using J2EE, and you dont have to with Spring or JBoss Micro.
Furthermore, our conversations about the architecture seem to be shaping geoserver into a much smaller core, with a wealth of services and utilities "plugged into it". Enterprise software is notorious for being very monolithic.
All that being said I am not a marketing consultant so who knows, I would like to bring the name out for public debate as well.
      Bye Paolo
Bye
Paolo Rizzi
Justin
Spring)
couple of
reasons:
3) It is integratable with pretty much of the other web technologies out there, including struts
However my number one reason for liking Spring is the popularity it is gaining. For instance, this year at OOPSLA Spring received much attention.
I eagerly await the full evaluation, I have done some research, here are my thoughts.
From what I can tell JBoss MicroContainer offers everything that Spring does. However it still seems like JBoss Microcontainer is still the new guy on the scene and most people are still using spring.
So all in all I would have to say that my choice at this moment is definitly Spring.
-Justin
I looked at:
good work!!!
hope to be able
Bye
Paolo Rizzi
.) OSGi
Light, flexible and embeddable enough, but it has nothing more than JBoss / Microcontainer has, and it's not enough mature.
.) Spring
AOP, etc.).
--- I'd use it. ---
.) JBoss / Microcontainer Very light and flexible. The new Microcontainer is embeddable
containers.
(MVC, AOP,
etc.).
--- I'd use it. ---
expert in this).
what I've used
Microcontainer.
Ag.Mobilità
Hi Paolo,
has not yet
been decided on, still in the evaluation stage. OSGi is just the first one that I have had time to document. Next I plan to evaluate Geronimo.
Please feel free to add JBoss to the list of candidates. It you have the time I would love if you could write some docs about why you think its a good way to go.
The list of technologies on the page is by no means complete so please add anything else you think should be there.
-Justin
dedicated to the
design. It would be nice to start refining some of the great discussions that have been going on with OpenSDI and some of things you
guys have
been doing over the last little while into a architecure and high level design.
Justin
first one
you addressed???
Dave's sentence:
"...ps. from the last meeting, it appears the "data/catalog" portion of the framework will be somewhat like an expanded
"DataEngine" (from the IRC meeting)...".
can I find it???
Bye
Paolo Rizzi
we couldnt
attend.
enough...
the two new
of the major
system for
and WMS and
example, the SIS
Enterprise
platform for
We have discussed how we would provide services for most of what's been
meetings. I think
you're going to be very excited about it. We are going to write up our
interest!!!
dave
    Bye Paolo
(from the IRC
meeting).
AVVERTENZE AI SENSI DEL D. LGS. 196/2003 Le informazioni contenute in questo messaggio di posta
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
messaggio stesso,
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
contrario ai
messaggio stesso,
copiarlo, od
End of 2005
information
Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
riservate. Il loro
messaggio, per le
questo messaggio
darcene notizia
contrario ai
messaggio stesso,
copiarlo, od
Justin Deoliveira
AVVERTENZE AI SENSI DEL D. LGS. 196/2003 Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
Justin Deoliveira
Justin
Whilst it may all be marketing, uncontrolled marketing power drives social behaviours and politics these days and has not made the world a better place. >:o
Seriously, Enterprise is an "inwards looking" concept - its the generation of software characterised by monolithic solutions and Standard Operating Environments that came before "service oriented architectures" that emphasise well behaved components - some of which get exposed across enterprise boundaries.
I would have thought that geoserver is intrinsically "pan-enterprise" in concept. I'm not sure what a better name is, but it would be sad to see the dream of creating usable data services to enrich society's decision making capacity fade into obscurity.
Rob Atkinson
The difference between "Enterprise" and "Open Spatial Infrastructure" - that would make it "GeoServerOSI" pronouncedly "Aussi" for Rob :wink:
Justin
Rob Atkinson
Sony(tm)PSP. Click here to play: Best Open Source Mac Software 2024
