R: Re: [GRASS-user] problems with v.edit
I have a problem with v-edit.
I have to break a vector line
into two parts near a point. I gave this command:
v.edit
map=ret_125
layer=1 type=line tool=break thresh=$ris_edit
coords=$x,$y snap=no
where " $ris_edit " depends on the
resolution of the DEM raster map,
"$x" and "$y" are the coordinates
of the point.
are you sure that threshold value is enough to select
vector feature
which you want to break?
v.edit map=ret_125
tool=select thresh=$ris_edit coords=$x,$y
Martin
Martin Landa
<landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Hi
all,
the point is 6 meters far from the line and I used a threshold of
100 meters.
Thanks you all,
Chiara.
Attiva Tiscali Tutto Incluso: telefoni e navighi senza limiti A SOLI €10 AL MESE FINO ALL'ESTATE. Attiva entro il 22/01/09! http://abbonati.tiscali.it/promo/tuttoincluso/
2009/1/21 chiaraercoli@tiscali.it <chiaraercoli@tiscali.it>:
v.edit map=ret_125
100 meters.
so should I understand that result of tool=select no feature is found?
Can you send me sample data?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
