r.report
I am wondering if there is a way to use r.report
to give me data on just a portion of a region.
For example, my region is set up for the Great
Lakes, if instead of using r.report for the whole
region I just wanted to do r.report on one lake how
would I do it? Is this simply a matter of setting
a new region.
Thanks
Jim
You can set a new region.
You can also use a mask to outline areas which are not rectangular and that you
want to use to define your report area. You could use a map of the Great
Lakes to mask one or several lakes and then run r.report to get results from
just these areas.
Allan Axon
Ohio Department of Natural Resources |
Division of Geological Survey |
Coal Geology Group | Phone: 614-265-1030
4383 Fountain Square Dr. | FAX: 614-447-1918
Columbus, OH 43224-1362 |
Internet: aaxon@ogsun1.dnr.ohio.gov
