r.slope.aspect
The interactive verion and the manual have not been updated. I have
reported this as a "bug" to be fixed. r.slope.aspect was upgraded
to do 360 of aspect. The manuals and interactive versions may have been
overlooked (if not, they certainly weren't put on the ftp site).
|I am using r.slope.aspect to reduce the possible 360 degrees of aspect
|down to 8 principle directions (N,NE,E,etc). When running the program
|r.slope.aspect interactively, the header tells me that the aspect
|output will be categorised into 24 directions, as does g.manual.
|However, the output is in 360 categories.
You can use r.reclass command line version very easily, if you use
the command line version. You would do something like this:
  r.reclass i=aspect o=aspect.8
  1 thru 45 = 1
  46 thru 90 = 2
  91 thru 135 = 3
  136 thru 180 = 4
  181 thru 225 = 5
  226 thru 270 = 6
  271 thru 315 = 7
  316 thru 360 = 8
  end
You probably need to use a differnent set of rules since you want N,NE, etc.
but they wouldn't be har to work out and once you have them, save them in a file
and run r.reclass like this:
  r.reclass i=aspect o=aspect.8 < aspect.rules
Michael Shapiro U.S. Army CERL
email: shapiro@amber.cecer.army.mil Office of GRASS Integration
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
