r.slope.aspect
While modifiying r.slope.aspect to work with lat-lon databases,
command line version of r.slope.aspect was also modified to
compute 360 degrees of aspect instead of 24 categories of apsect.
The interactive version (which gathers user input an then runs
the command-line version) was modified to reflect these changes
but was not put on the ftp site (oversight).
The 4.0 interactive version says it will create 24 categories of
aspect, but if you installed the new command-line version you get
360.
The interactive version still has some minor problems (which
existed in 4.0). When these are corrected, this new version will
be placed on the ftp site.
|Hi, I changed r.slope.aspect in june.
|You have the old manual, and header needs to be changed
|thanx for bringing it to my attention.
|There should be as many categories as the number of distinct
|integer values of aspect the program computes.
|I think the simpliest thing to change it to less cats
|is to run r.rescale 1,24 or something like that.
|I'll ask my supervisor, Michael if I should make it one
|of the options: to scale the data after the calculation
|is finished.
|Olga
Michael Shapiro U.S. Army CERL
email: shapiro@amber.cecer.army.mil Office of GRASS Integration
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
